need serious help with cranksh
I cant get the crank pulley off i evan have a puller for it it just gets so tight i cant turn it anymore it's pissing me off i think i might have messed up the inside of the pulley where the bolt goes because the bolt on the puller goes right in the hole where the bolt goes and i might have striped it because the bolt wont go in now i need help guys anything will help please please please.
Make sure you have the washer out of the pulley as well as the bolt. I have never had my pulley off, but I have seen where you need a long skinny rod to go down inside the threads of the crackshaft, because the pully has a flat spot where the bolt bottoms out on it. If you can, get a mirror and look down inside the pully were the bolt goes, and see if it is flat inside there, or you can see the crackshaft. If it is flat and you can not see the crankshaft, you are just pulling on the pulley, and not pulling the pulley off the crank. I hope this makes since to you, cause it confused me just typng it al out. <IMG src=smileys/smiley2.gif border="0">If not, let me know and I will try and clear it up alittle better.</P>
Flying5.0</P>
Originally Posted by USAMuscle
Crackshaft...<IMG src=smileys/smiley5.gif border="0">LOL. Sorry I just had to pick on that.
Hehe whoops my bad. <IMG src=smileys/smiley17.gif border="0"></P>
well on the end of the long bolt for the puller, there should have been a "cone" shape plug that pushes against the outside of the crankshaft...the puller should not go into the crank thread hole at all, if you messed of the threads in the crank, you better try cleanin them up with a tap or it looks like your taking your engine out for a new crank<IMG src=smileys/smiley5.gif border="0"><edited><editID>Black Horse</editID><editDate>38001.8585185185</editDate></edited>
I got it after about an hour or so i had to place a washer in front of it so it did not go into the shaft and it worked but the threads were stripped and i re threded them and now its back together i was sh*ting my pants for a while but it was worth it i am shure i will get better at working on my car as i get older i amonly 17. Thanks for the replys and a glass mirrior would of helped i did not think about that i was trying to stick my head down there and almost got stuck in between the fan and motor LOL<IMG src=smileys/smiley5.gif border="0">
mungodrums
Oct 7, 2015 04:01 AM
Sep 3, 2015 07:14 PM
