Wierd engine sound when cold or idling
Old Dec 31, 2005 | 02:07 PM
spederman's Avatar
spederman
Default Wierd engine sound when cold or idling
I'm confused with this new engine sound that seems to have appeared out of no where. I have a 2002 GT 5 spd. The first start of the day when my engine is cold and i drive off, which ever gear i'm in if i take it higher than 2K RPM's, i get this wierd rattling/vibration sound from the engine compartment. Its really hard to describe the sound. Its kind of like a metal to metal rattling vibration. Like say if you had a fan with metal blades and while it was running you barely touched another piece of metal to it so it would make a rattling/vibration sound. It is only there when the engine is cold and only when i rev past 2K and it stays there no matter how high I rev. Although once i get to like 3500K the exhaust and engine is so loud it drowns out the sound of the rattling.
New thing today i noticed is that this same sound is kind of there when i am at a stop light in neutral and i rev the engine to the same rpms. This happens even if my engine is warm. It makes almost the same rattling/vibration sound. It sounds like its coming from under the hood on the passanger side. I dont know if this is the same exact sound but it sounds really similar.
Anybody have this or know WTF i am talking about? Thanks guys.
Old Dec 31, 2005 | 03:57 PM
dlazrael's Avatar
dlazrael
Default RE: Wierd engine sound when cold or idling
Sounds like the Throttle Body butterfly, I don't know exactly how to tighten it, and actually I need someone to tell me :-p. (not trying to jack the thread). I've got the same issue, and I've narrowed the sound down to the TB, but I dont know how to tighten he butterfly to stop the rattlin :-p (I've got the 03 Cobra 63mm dual bore, if that helps on how to tighten it)
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
mtxplod
Aug 29, 2015 01:43 AM
yurizx6r
Aug 11, 2015 07:50 AM
HIS S-197
Aug 10, 2015 05:47 PM
