clutch problems (chatter, etc)
Old Jan 11, 2006 | 04:19 AM
Birdieman4's Avatar
Birdieman4
Default RE: clutch problems (chatter, etc)
It sounds to me like they didn't install it properly. I highly doubt the TB shattered the fork. If the clutch wasn't the correct size, or if it was installed incorrectly, it is possible the fork was rubbing on the pressure plate at full disengagment. The entire time, the noise has been from the TB, but the scraping sounds you heard were very possibly from the fork touching the pressure plate or something else in the bellhousing. Take it back in and have them look at where the ball end of the fork is at full depression of the clutch pedal. They'll be able to see if its rubbing anything. -And they should have seen that before they originally gave it to you, and also noticed it on the short test drive of your car.
Old Jan 11, 2006 | 05:51 AM
jmmorgan82's Avatar
jmmorgan82
i have just under 100k, i bought the tranny off ebay, it has 27k and i saw the documents to prove it. it shifts perfectly, its just the clutch that is acting strange.
Old Jan 11, 2006 | 03:41 PM
Birdieman4's Avatar
Birdieman4
I'm tellin ya, what is probably happening is the ball on the end of the fork is rubbing somewhere. Have you brought it back to the shop that installed it?
Old Jan 11, 2006 | 03:43 PM
jmmorgan82's Avatar
jmmorgan82
yea i did, and they sware up and down its the clutch components failing
Old Jan 11, 2006 | 07:40 PM
M1ke's Avatar
M1ke
well then tell them to fix it or find out why. They did the installation and you are unsatisfied.
Old Jan 11, 2006 | 09:06 PM
Birdieman4's Avatar
Birdieman4
Did they confirm the rubbing inside the bellhousing? They should be able to tell you what is wrong. They are being too general with you. Find out exactly what part is 'failing', according to them. I doubt any parts have failed, but they might soon if you don't figure out what the problem is. Don't let this shop jack you around. If they claim the 'clutch components' are failing, have them show you exactly what part(s) is failing. I doubt they'll be able to. Are they standing behind their work? Ask THEM that.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
