What oil does everyone use here???
RE: What oil does everyone use here???
Mobil 1 Full synthetic 5w20. I also use a Purolator PureOne oil filter. They get better oil pressure than Fram. I've also used Valvoline SynPower 5w-30 and Castrol Syntec 5w-20.
ORIGINAL: Emann0007
Ford Motorcraft 5W-30. Am I the only one not running synthetic???
Oil is the lifeblood of your car. If you want the engine to last longer, then you should use synthetic. I'd much rather spend 40 dollars on oil then a couple grand on an engine. Plus I get a 20% discount!
I use Pennzoil's synthetic oil. Whatever its called. 5w20. Probably need a little thicker living in florida where today its freaking 70, in January, but I'll stick with what the factory says to use.
