This 4:10 Kit any Good?
RE: This 4:10 Kit and Good?
ORIGINAL: 03sonicgt
Is this kit come with the bearings I need?? Are there any other stupid things I will need to install them?? Also, does this seem like a good deal?? Thanks, Kyle
Alright aiextreme, I appreciate it. So I get that 4:10 kit, with the speedo calibrator, which will work on my car right?? (I have an 03 5spd GT). The royal purple oil and that bearing kit for 8.8 rear end will all I need for a succesffull install?? Also, whats a good price for the install on these bad boys??
You really don't need to go crazy on the bearing kit seeing the car is an 03 and if it ahs under 36000 there is no need to spend the extra cake on bearings.
Make sure you get a nice quaility fluid.
And be warned that the gears will skew your dyno results a bit.
I dynoed my car and put down 245 with 4.10s. The guy who did the dyno pulls also did the install on the gears and he said that the car probably would put down over 250 if it were stock gearing. It's hard to explain why it is that way, jsut know that it is.
God, gears aren't as cheap as I thought they would be altogether. I thought about order gears and a tb and plenum. But maybe I'll just go with gears for now. Do you guys think I should get the bearing kit now just to be safe? My car has 31k, and its an 03. I don't usually go cheap, I'd rather be safe than sorry. Thanks, Kyle
When I was first pricing for gears I was getting quotes around 500 not including the gears.
It took a couple of months but I got I found a guy that did the gears for 260 and they were done right. I watched the whole thing and the rear end was set-up perfectly.
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
09-01-2015 08:16 PM
