2inch drop vs. 1.5 inch
RE: 2inch drop vs. 1.5 inch
nah not in it for drag racing...I really want to go with the 2.0 I think...TO give it that good look...I just need to find cheap cc plates....Anybody know if the offset rack mount bushings will afect my drop? As in, not lower it as much?
ORIGINAL: gt96stang
I'm planning to go with eibach pro-kit which lowers it only 1.5" so I will not have to mess with c/c plates.
Either way is fine, whatever look you want from your car. Only one major thing to keep in mind....you can only drop your car's suspension up to 1.5" from stock without having to invest in many other suspension mods to realign your car's front end geometry. Anything lower than 1.5" and you will need caster/chamber plates and a bumpsteer kit to compensate for the lowering. If you drop your car 2" and do not do this, your tires will wear out in record time, not to mention unnecessary wear on your other front end parts. I use the Steeda Sport Springs that drop the car almost 1.5" and my alignment is perfect without all the extra parts. The springs also give the car a nice rear to front rake. I think it looks plenty low enough as it is. Don't also forget, around 2"+ drop and curbs, etc. can get to be a hazard when you try to park, not to mention large dips and ruts in the road. 2"+ and you will find your car bottoming out more than you might like. Check out my Stang in the members photo gallery:
https://mustangforums.com/photosearc...filter=&page=1
Number one, you have to please yourself. There is no right or wrong in this area. Good luck!
H&R supersports here.....2" front, 1.5" rear....all you have to do is know how to drive a lowered car and you will be fine.
This thread will answer all your questions, its STICKIED FOR A REASON!!
https://mustangforums.com/m_617202/tm.htm
I've read that entire sticky 2x...Doesn't answer everything.....Like if bumpsteer kit/offset bushings are ABSOLUTELY necessary, or if cc plates is enough for the 2 inch drop (which is what I', going with...I just spent a **** load of money on rims and tires and and not going to waste good tread...Thats why I ask these questions....And I am most likly buyng this kit tomorrow....so......
ORIGINAL: nopropslaw
so what was your total drop? What did the springs claim? So those aluminum offset bushings helped make your alignment possible? That sounds good...I am looking at those same brand springs but the kit comes with the shocks and struts as well...I really hope it lowers it the 2 inch it claims...
