Shift lights???
Old Jan 13, 2006 | 02:00 AM
Chopper's Avatar
Chopper
Default Shift lights???
I need a stand alone shift light.I was leaning toward the Raptor but have read that people have been having problems with it setting off the CEL.I know Autometer makes very good products also.It must be one of the small units because if I get pulled over I don't want the cops to think that I might drive recklessly.So which one would you get?
Old Jan 13, 2006 | 02:27 AM
Dark_Horse's Avatar
Dark_Horse
Default RE: Shift lights???
Raptor looks so much better IMO, i have never hear of it setting off any CEL odd i dont know why it would
Old Jan 13, 2006 | 02:45 AM
Aixtreme89's Avatar
Aixtreme89
I have a g-tech pro which has a shift light built in. You can set it to any rpm you desire. It has 4 LED's pretty bright, just as good as those shift lights mentioned, I bet. Plus you can do alot of other things with it.... http://www.gtechpro.com/test.html
Old Jan 13, 2006 | 08:30 AM
DR8907's Avatar
DR8907
ORIGINAL: Chopper
I have my shift light mounted in the left air vent - you should condsider that because it leaves a clean look to the car and looks really good when it goes off at night. Mines autometer by the way and its really good.
Old Jan 13, 2006 | 08:43 AM
SilverGTV8's Avatar
SilverGTV8
I have not had any problems with my Raptor. You just need to be very careful with the wire harness and 100% certain of the feed line for the signal. It takes some time to find but it can be done. Tying in to power and ground should be done carefully too. I was able to tie in to a switched line next to the PCM and ground it using the PCM grond lug.
I put mine in the center of the gauge cluster and it looks good.
Old Jan 13, 2006 | 10:58 AM
Chopper's Avatar
Chopper
ORIGINAL: DR8907
ORIGINAL: Chopper
Thats where I'm looking to hide mine.
Old Jan 13, 2006 | 02:22 PM
pdk's Avatar
pdk
raptor has 7 led's
mines mounted on the steering pod with velcro. tried on the gauge pod like above but the wheel interfered with the light in certain positions. no problem seeing the light even during the day
Old Jan 13, 2006 | 03:27 PM
Zoie_daGT's Avatar
Zoie_daGT
I would have to go w/ Autometer because that is what I have and I like it.
Old Jan 13, 2006 | 04:19 PM
Chopper's Avatar
Chopper
ORIGINAL: pdk
raptor has 7 led's
Never thought about Velcro.Good idea.Keep these ideas coming.
Old Jan 13, 2006 | 07:32 PM
MustangChris04's Avatar
MustangChris04
what is a warning light for?
