(((HELP)))What Size Gears Do I Have????
I know I should know this but how can I tell what size gears my 98' GT AOD(stock) has? I have the door jam sticker and the little aluminum tag still on the pumpkin but do not know how to read it. I know its a no brain-er but I need some help please. Thanks!
RE: What Size Gears Do I Have????
prop the back end up and turn the wheels once and see any many times the drive shaft turns
the stock is 3.27 so if it turns 3 and a fourth times you have stock
if it turns 4 times or more then you got the 4.10 or up
you can do the math
Try this im not sure about the sticker
you can do the math
ORIGINAL: bobjenkins
you can do the math
you can do the math
whatever they are, swap them out for 4.10s
