ENGINE PROBLEMS
Old Jan 15, 2006 | 09:12 PM
tony28's Avatar
tony28
Default ENGINE PROBLEMS
Hey, i have a 1999 GT and the check engine keeps coming on. the code is PO306, a misfire on cylinder 6. ive had this problem before and i replaced the spark plugs and it was fine for about a week. now its hesitating and acting up the same way again and giving the same code. what else can i replace. the coils maybe, or ive also heard that the fuel rail may be clogged?
Old Jan 15, 2006 | 09:56 PM
Chopper's Avatar
Chopper
Default RE: ENGINE PROBLEMS
Try changing the injector in the bad cylinder with another and see if the problem follows the injector.If so replace or clean the injector.
Old Jan 16, 2006 | 12:37 AM
Jglisson's Avatar
Jglisson
Injectors are rarely a problem. You have a bad coil pack. What are you considering to be cylinder # 6...assuming you are sitting in the driver's seat...
Old Jan 16, 2006 | 01:13 AM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: tony28
Sounds like a bad coil. If the fuel rail was clogged, im sure all 4 cylinders on that side would be affected as well. Switch the coil and go from there.
Old Jan 16, 2006 | 01:48 AM
tony28's Avatar
tony28
cylinder 6 would be the third one on the left (from drivers seat). Ok thanx ill try replacing the coil and go from there.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
