Both Steeda, & March make good pullies, but only go for a T/A if you are not going to get a chip later, otherwise you'll be wasting your money.</P>
no having a chip allows you to adjust the timing or getting a timing adjuster allows you to adjusts the timing you can get them both it wont hurt anything</P>
what gsxr is saying if your not planning on getting a chip then get yourself a timing adjuster but if you plan on getting a chip then wait because you can adjust the timing through a chip </P>
That is incorrect. You don't need a chip for timing adjuster to provide benefits.
</P>
What I was trying to explain is that a custom chip can be programmed to provide every benefit a timing adjuster can. If you get a dyno tune, why would you want to even change the timing to your car? If you add something to your car that would require retarding the timing a little such as a power adder, you NEED another flash anyway.</P>
