Non-PI GT Guys...
#21
RE: Non-PI GT Guys...
ORIGINAL: redstanger
still moving up just the lift from .473 to .505 is still a good move for nonPI heads. PI cams are good on nonPI heads thats just plain and simple. just bumping up .032 is a good change in lift. VTstage1's, are what 600 dollars and there is a .550 lift. which is a .045 lift increase from the stock PI cam. putting VTstage1's on a nonPI motor is dumb. so if their is a guy that wants a drivable car and if you dont want to spend 600 dollars on cams when you can get used stock PI cams for a third of the price that are a FORD product. cam install is somewhat easy and fast. work 3 hours to get around 30hp is a good swap but thats only me.
MM&FF did a cam swap with comp cams 262's on a non-pi motor and only picked up 20hp.
#22
you are anr not going to get 30hp by swaping in stock cams. maybe on a blown car or something.full PI swaps add like 50 and there is no way 30 of it is from the cams. its the better flow and raised compression. i never said that putting Stage 1 cams in a npi motor will help alot. im saying why not just do a PI swap. that is alot more power
#25
some people cant afford PI swap. have you thought of that. some people have to work for there money. mommy and daddy dont just give them money.
#26
redstanger
Status: online some people cant afford PI swap. have you thought of that. some people have to work for there money. mommy and daddy dont just give them money.
#27
just a little FYI most people dont talk about flywheel hp, they almost always talk about what it gets to the ground. and VT stage 1 cams are like 25hp so i dont really thing stock cams are going to add 15. maybe 10
