Headers install?
Old Jan 24, 2006 | 01:07 AM
hillbillymustang's Avatar
hillbillymustang
Default Headers install?
Can shorty header be installed in a 1999 GT in your driveway with out jacking the car up and doing it from under the car.
Old Jan 24, 2006 | 01:21 AM
rbstang's Avatar
rbstang
Default RE: Headers install?
no. you gotta disconnect your stock headers from the stock midpipe. and some other stuff.
Old Jan 24, 2006 | 01:28 AM
hillbillymustang
So are you saying it is probally easier to have a shop do it?
Old Jan 24, 2006 | 01:30 AM
rbstang's Avatar
rbstang
if you have like no room to work ie no driveway, garage and none of your friends do then yes. otherwise you can buy a jack and jack stands and do it yourself in the driveway or garage.
Old Jan 24, 2006 | 02:53 AM
MustangMafia's Avatar
MustangMafia
I would be really careful if you are trying to do this yourself. The cat-back and midpipe I could see you doing yourself, but unless you have a fried that knows what he/she is doing, I wouldnt want to try this yourself. The headers are supposedly quite a bit harder than the rest of the exhaust, shorties or not.
My $0.02
Old Jan 24, 2006 | 02:25 PM
Sap's Avatar
Sap
Here it is, straight and honest.
Installing headers is lengthy and a pain in the ***.
That said here is what I recommend, first off you will need to jack up the car, put it on jackstands and chock the rear tires. The install may take more then one day, in fact I recommend a 3 day weekend. Take your time and be patience, if you have access to air tools, ratcheting wrenches and lots of WD-40, you will be better off. Finally, this is a trying install, not because its hard, but because it takes alot of time and can seem overwhelming at times, TAKE YOUR TIME and take breaks to get your bearings. Have friends help if you can, having another hand can sometimes make the job alot easier, that said good luck. Also if you haven't bought the shorties yet, I would recommend against it, most if not all people on here will, there is little to be gained and for such a pain in the *** install you might as well get long tubes.
E.
Old Jan 24, 2006 | 05:11 PM
badsp0rk's Avatar
badsp0rk
ORIGINAL: MustangMafia
My $0.02
i heard shorty headers are pretty easy to install.
then again, i heard midlength were, too, and they certainly were not..they barely even fit!
Old Jan 24, 2006 | 06:53 PM
Albizo66's Avatar
Albizo66
badsp0rk how does the stang sound now? any clips?
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
