mustang tuning catless x-pipe...good or bad??
Well i saw mustang tuning makes a catless mandrel bent 2.5 xpipe for $164. I'm not really worried about the price, more along the design and effectiveness. Is anyone running these or have installed them? I'm running the magnaflow maganapack cat back now, and i'm not sure if it'll fit up properly.
RE: mustang tuning catless x-pipe...good or bad??
I guess if you have to cheap out on a part of your exhaust, the midpipe would be the one to do it on. Just watch out for rust, because I doubt it's stainless steel. As far as fitting goes, it probably won't give you any troubles because both your cat-back and the midpipe are built to factory specs. I have also heard from people that if you go with a cheap aftermarket catted midpipe, you will still throw a code, but that is just speculation as far as im concerned. And as far as performance, it will probably be the same as all the rest because theyre essentially the same thing.
ORIGINAL: Matts00GT
Even if it's stainless steel it can still rust. It won't rust as quick, but it will eventually develop some rust, unless it never gets wet.
Ive had a UPR one on my mustang for 2 years now (same price, probably the same design) and I love it. It isnt raspy or annoying, those rumors are complete BS. and yes its catless. The install was fairly easy, and it fit perfectly.
nice!! well if thats the case i guess i'll be running that with the new tuner. Anyone install a tuner at the same time as thier x-pipe?
