comp cam
Old Jan 28, 2006 | 03:17 AM
  #21
GSXRIntensity's Avatar
GSXRIntensity
Default RE: comp cam
ORIGINAL: code3GT
All depends on your tuner. I think GSXR is running the 270's.
I think so too! My heads are all done up though. I had Fox Lake upgrade my stock heads to Stage 2 spec which include:
*"Fox Lake Stage 2 P.I. heads flow a whopping 223 cfm intake and
195 cfm exhaust @ .550" with Mod Max valves!
Stage 2 Assembled heads:
Includes Ferrea oversized valves, Manley hi-rev springs, solid bronze guides, Viton seals and Pro-Assembled (does not include cams)
Springs are good for .580" lift and 6500 rpm in most applications"
Ron also hooked me up with Comp rockers & solid lash adjusters for my car, as well as port matching my heads with my P-51 intake
I can't wait until tomorrow!!!!!!!!!!
*taken directly from Fox Lake's website for those interested: www.foxlakeracing.com
Old Jan 28, 2006 | 09:49 PM
  #22
BCisme's Avatar
BCisme
ORIGINAL: code3GT
ORIGINAL: 04BlueGT
ORIGINAL: BCisme
with 274's you'll have to notch the pistons and have a set of $400 valve springs. the comp 262's or 268's, or even 270's will be a good choice for you. i'm running 278's, and had to have my pistons notched for the cams to clear.
Aren't the 268s non-PI only? Come to think of it, the the 274 is non-PI. The '01s are PI, right? If so, you'll need the 262, 270, or 278 'AH'.
Code, do you think he could run the 270s with a decent idle? (He'll need springs, tune, and gears)
well comp uses the number codes for all the mod motor cams, even 4V's. i dont recall all the specific number applications, but MM&FF did a pi cam test with like 6 different grinds.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
