comp cam
ok here it is. I am thinking of puting comp cams xe274h in my 01 gt. the reason is i do not want to worry about ptv contact. do you think i will have good gains from these? also it is a daily driver in the summer so let me know what you think thanks for your help
What other mods do you have or do you plan to do with such aggressive cams? Not really the best for daily driving either, because you may have idling problems with it. the xe274 is pretty much a drag racing only cam that is very peaky. I'm sure if you have an all out drag car that you'll love it, but you have nothing but a cat-back & a shifter...I'd look at other mods first.
ORIGINAL: doughboy
so code is it to big of a cams for me what do you think
ORIGINAL: doughboy
Just my opinion, but like I said...they are big cams. Do you know the exact specs on them?? Also, depending on how much of a DD you want. My cams are pretty big for a DD and it has been a BIATCH to tune for idle and such on a DD. You have to remember, with a DD there is alot of stop and go driving and it's a pain to tune for the big cams so your car doesn't die when you stop. Also, you have to take into consideration running with your A/C on. When the A/C compressor kicks on, your idle drops which can wreak havoc on keeping the car running while slowing down to stop.
I am not saying it can't be done, but you will need a good tuner that knows what he/she is doing. Also, with that size cam, headwork, exhaust and intake is a must to see the full potential. I am unsure what the powerband is on those Comps, but I am guessing it's probably in the 2500-6700rpm range and it will be hard to twist a stock bottom end that high.
ORIGINAL: code3GT
ORIGINAL: GSXRIntensity
Thanks for that Mitch; saved me a lot of typing lol! How are ya?
ORIGINAL: code3GT
Same old, same old. My wife is driving my car to work tomorow....she's killing me LOL
