Another lowering question...
Old Jan 30, 2006 | 04:12 PM
The02GT's Avatar
The02GT
Default Another lowering question...
I know its been heard 2309472 times but what is the absolute lowest you can drop a 02 gt with out doing caster camber plates??? ive heard 1.5 and 2.0, so which one is it???
Old Jan 30, 2006 | 04:21 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
Default RE: Another lowering question...
1.5" is already pushing the limits of your stock suspension geometry. it really depends if you are able to get your car aligned or not. some people are ok at 1.5" drops, and others need c/c at 1.5" drops.
Old Jan 30, 2006 | 04:39 PM
JonBeast's Avatar
JonBeast
Moderator
It all depends.....after you drop your car....you have to check out the camber. If its pretty negative, a shop isn't going to be able to align it. Usually 1-1.5 is okay....you will just have to check it out.
Old Jan 30, 2006 | 05:52 PM
xx9gt6xx's Avatar
xx9gt6xx
You can get away with 1.5" on the SN95's. But on the 99-04's 1.25" would be the limit without C/C Plates I think...
Old Jan 30, 2006 | 05:54 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
I thought the new edge and sn95 suspension setups were the same.
Old Jan 30, 2006 | 07:41 PM
Deannostang's Avatar
Deannostang
For the millionth time......1 1/2 inches.
Old Jan 30, 2006 | 07:42 PM
xx9gt6xx's Avatar
xx9gt6xx
They seem the same, but the wheel gap for the SN95 resembles an off-road vehicle more than the new edge Mustangs...
Old Jan 30, 2006 | 08:01 PM
JonBeast's Avatar
JonBeast
Moderator
The suspension is the same 96-04 (spring wise)
Old Jan 30, 2006 | 08:12 PM
Quickshift_02GT's Avatar
Quickshift_02GT
I asked Maximum Motorsports the same question a few months ago.
I inquired about their H&R springs that are 1.5" drop, and they said it would be perfect without the need for any bumpsteer or caster/camber plates. Bumpsteer was a definite no, but caster/camber was at the very limit. It may or may not need it depending on individual applications, but in their experience...it was most times no.
Old Jan 30, 2006 | 08:42 PM
04BlueGT's Avatar
04BlueGT
If you don't want the hassle or cost of CC plates or bumpsteer, you can always go with offset rack bushings with the 1.5 drop. It will still need an alignment, but it will work. I recommend the indexed aluminum offsets, as they resist rotation within the rack.
I have them and have had no problems.
BTW, they cost like $40 and you can put them in in about 15 minutes if you have any mechanical inclination.
