Vortech and what Fuel System?
Kit Includes
Vortech supercharging systems deliver maximum value for your performance dollar. Most system is 100% complete, right down to the wire ties.
* Compressor matched, computer aided designed and machined Vortech centrifugal supercharger
* 3.60†Supercharger Pulley
* 6 Rib Pulley Retainer Assembly
* High flow air intake system with a K&N air filter and specially formed polypropylene plastic inlet ducts for minimum restriction and superior fit
* 255 Walbro Fuel Pump
* 38lbs Fuel Injectors
* ECM Chip Package
* Heat resistant silicone hose coupling
* Premium grade flex hose
* Stainless Steel Clamps
* Carefully designed and flow tested cast aluminum and/or roto molded urethane air Discharge Tubing
* Compressor By-pass Valve
* OEM style single cast 356 aluminum Mounting Brackets heat-treated to T-6 specifications for strength
* Integrated Belt Tensioner
* Premium Drive Belt
* Heavy-duty Mounting Hardware
* Tie Wraps
* Heavy-duty engine oil lubrication system
* Step-by-step, fully illustrated Installation Manual
* 3-year limited warranty on most systems
* ECM Chip Package
* Tie Wraps
Looks like a Vortech kit will come with fuel pump and injectors.
Sep 16, 2015 07:53 PM
Sep 10, 2015 08:39 PM
