Another stupid tuner question.
Is it possible to use a handheld tuner (such as diablo or sct) to turn off your 02 sensors and calibrate for gears without having to have a performance tune loaded?
I know they can turn off your CEL and calibrate your speedo. But I dunno if it is part of the "performance" tune the tuner comes with, which you need to run premium to use.
you can modify the stock tune, w/ a predator there a 2 options performance tune or stock hp tune. if you choose stock and change those 2 things it will gain no perrformance but i think it will give you a new tune and not just modify the one on the computer already
So if I modify the stock tune for the speedo/sensors, that becomes the new stock tune and create a backup file of that? So I could then give the tuner to somebody else and they could use it if I wanted to? The reason I am asking is because I plan on doing A LOT of drivng this summer and if I get 4.10 gears and have to run premium here, I will send myself to the poor house. I would rather just be able to use the tuner for the Speedo/02s now, then after the summer load the performance tune when gas is a lot cheaper and I am not having to drive around nearly as much.
The tuner will let you modify for O2s, gears etc without modifying performance. However if you want to give the tuner to somebody else to use, you have to return your car to factory settings first. The tuner can be used on only one car at a time.
ORIGINAL: pete1665
Daddys Girls GTs
Sep 14, 2015 08:46 PM
ernesto-619
Sep 10, 2015 01:32 AM
