P1152 engine code
Old Feb 27, 2006 | 11:23 PM
  #41
beheivjer's Avatar
beheivjer
Default RE: P1152 engine code
i changed out the front o2s again today maybe i had a bad one well see
Old Mar 3, 2006 | 03:03 AM
  #42
beheivjer's Avatar
beheivjer
changed 02 and fuel pump and no light after 3 days
Old Mar 11, 2006 | 08:30 AM
  #43
Lucidus's Avatar
Lucidus
Still no light?
Old Jan 10, 2008 | 06:52 PM
  #44
ranger69's Avatar
ranger69
dude i got the same exact problem, was it the injectors?
Old Jan 10, 2008 | 09:59 PM
  #45
5.0.gabe92's Avatar
5.0.gabe92
i have the same problem dont know what it is it been like a monthi'v been haveing these problem. so i took it to a shop and the said the it was the computer???but i dont think that what it is. so im going to take it to fords and see what they think it is. but keep us posted thanks.
Old Nov 4, 2010 | 08:44 PM
  #46
cisurfer's Avatar
cisurfer
let me know too cuz im getting 1131 and 1151 codes on day and 1152 code the next, lean to rich makes no sense, changed intake manifold gaskets, repplaced injector o rings and have two new 02 sensors less than a year old
Old Nov 6, 2010 | 10:24 AM
  #47
deviousgt's Avatar
deviousgt
I had the same code (p1152) it's being set off after you install an o/r mid pipe due to the cats being gone sets off the o2 sensors. When you plug in your mils you should have your battery disconnected leave it disconnected for about 10 mins and the reconnect the light should turn off and as far as idle issues go try replacing the IAC it might be that
Old Nov 6, 2010 | 11:05 AM
  #48
cliffyk's Avatar
cliffyk
TECH SAVANT
I applaud your use of the search function, however thread is mostly over 4 years old, with the newest post being well over 2 years old. It's OK to start a new one after that much time has passed...
You can look up the codes here and see possible causes and diagnostic tips too. P1131, 1151, and 1152 all have the same causes and diag tips as P1130.
Old Nov 6, 2010 | 02:58 PM
  #49
cisurfer's Avatar
cisurfer
thanks cliffy, i also do use your site for the codes, when i first open my throttle i get a whistle noise coming from somewhere dont know where but its a vacuum leak obviously, i didnt realize this thread was this old haha
Old Nov 6, 2010 | 03:32 PM
  #50
cliffyk's Avatar
cliffyk
TECH SAVANT
Check everything in the intake between the throttle body and the MAF, any unmetered air (air that hasn't passed through the MAF) entering the intake would cause the problems you describe.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
zachary1988
Sep 4, 2015 03:04 PM
