Would this work???
Old Feb 11, 2006 | 08:46 PM
XxphantomsnypzxX's Avatar
XxphantomsnypzxX
Default Would this work???
well I have an auto 96 gt, I was thinking maybe I should upgrade the tranny instead of changing it to manual. After research, came across the Volvo V70 tranny. Idk what it is im still tryna figure it out, I know it came either 5 speed or optional 6 speed automatic. Would I be able to make it work with my mustang?
Old Feb 12, 2006 | 12:46 AM
wwmost's Avatar
wwmost
Default RE: Would this work???
why would you put a volvo tranny in there? it would be too hard to make it work. just get a shift kit and a stall and call it a day.
Old Feb 12, 2006 | 01:54 AM
XxphantomsnypzxX
b/c a 6 spd auto would acclerate quicker duh
Old Feb 12, 2006 | 11:39 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: XxphantomsnypzxX
Why do you think that? I highly doubt it would make much of a differance at all, that Volvo trans is made for the highway not for fast accleration. Honstly you need a custom bell housing and then a way to use the Volvo computor to control it as that trans is 100% electronic. If you think you need a trans with that many gears check out Gear Vendors, they make an Under/Overdrive unit that bolts right up to your trans.
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
