ANYONE ELSE HAVING HEADER PROBLEMS???
Old 02-17-2006, 01:53 PM
sonicgt
sonicgt's Avatar
Default ANYONE ELSE HAVING HEADER PROBLEMS???
i put a set of BBK shorties on my 02 GT a couple months age and its been nothing but a nightmare. on the driver side there is a small leak somewhere in the flange and ive been putting it off, but im finally going to fix it this week. i was wondering if anyone else has had a similar problem and what was used to fix the problem? thanks
sonicgt is offline
Old 02-17-2006, 02:04 PM
MustangMafia
MustangMafia's Avatar
Default RE: ANYONE ELSE HAVING HEADER PROBLEMS???
Just wondering, are they ceramic or the steel ones?
MustangMafia is offline
Old 02-17-2006, 02:17 PM
sonicgt
sonicgt's Avatar
chrome plated steel
sonicgt is offline
Old 02-17-2006, 02:41 PM
70 MACH I
70 MACH I's Avatar
I have the ceramic coated BBK headers, I'm finishing the install this weekend, whose header gaskets are you using?
John
70 MACH I is offline
Old 02-17-2006, 02:59 PM
Tim37
Tim37's Avatar
mine was leaking at the xpipe flange.
Tim37 is offline
Old 02-18-2006, 01:44 AM
sonicgt
sonicgt's Avatar
well the first time i used the ones that came with the kit but they werent worth 2 cents, so since it was leaking so badly from the ripped paper gaskets, i got a set of Copper SCE's
By the way i just fininshed the job tonight and boy was it a long day. make sure they headers are perfectly flat before you install them and make sure you use either locking bolts or use jam nuts because my nuts came loose since the last time i took the headers out. i also spread some hi-temp copper silicone around the ports just to be same because i sure as hell didnt want to take them headers out again.
i just got in and my car sounds great, just like stock headers again and boy am i so happy that all my header problems are gone. Just a little advise for fellow mustangers who are looking into gettin some headers. either expect to be working for about 6 hours to put them in successfully and never buy BBK headers, they werent worth the trouble they caused.
sonicgt is offline
Old 02-18-2006, 02:13 AM
meebix
meebix's Avatar
LoL, you are the first person I have heard on these boards that have had trouble with BBK Headers.
BBK Headers are not bad, by any stretch. Im sorry that you had trouble, but don't throw down the company for it. 95% of the people on here who have BBK Headers will say they fit perfectly and have caused no trouble.
meebix is offline
Old 02-18-2006, 09:22 AM
wwmost
wwmost's Avatar
mine fit perfect
wwmost is offline
Old 02-18-2006, 11:14 AM
pLaGuIeNtO
pLaGuIeNtO's Avatar
I will install mines today, I will tell you if I had any problems during the process.
See you later! ^^
pLaGuIeNtO is offline
Old 02-18-2006, 04:50 PM
Blinkstang
Blinkstang's Avatar
I had a leak with my MAC LT's, when I switched to my BBK's I made sure to get Stage 8 Locking Header Bolts and a brand new set of OEM FORD Racing Header Gaskets. Have had no leaks what so ever. The first time around I used the MAC gaskets and stock bolts, junk!
Blinkstang is offline
Quick Reply: ANYONE ELSE HAVING HEADER PROBLEMS???
