Taking off the dash....?
I bought the saleen gauge pod for my Boost and Fuel pressure gauges. How hard is it to take off the dash board? I need to do that to run the wires to the engine. I have a show Wed and get the car back tuesday... i didnt know if it is a realy pain in the *** or not.
dash board meaning? The gauge bezel around the gauge cluster? Which pod? A pillar or cluster pod?what yr stang?
autometer gauge install
this may help
this may help
well he might have a 99-04 that doesnt have a clock in the middle. he prob bought somthing like this https://www.rpmoutlet.com/ezRetail/s...hp?msg_id=1004
the whole dashboard is a pain to get out, but not hard. you have to drop your steering wheel column (4 bolts holding it up after you remove the 2 cover plates) and you have to remove your glove compartment+both kick panels+center console (including shifter bezel of course) radio/ac bezel, front seat reccomended passenger not needed but helps a lot, and the defrost vent ontop of the dash (just pops out). there are 3 bolts on either side of the dash (identical locations but on different sides) then there are a total of 6 around the shifter area, and 3 ontop of the dash. thats how to get the whole dash out.
saleen gauge pod is the cpillar one right? should be able to run them through a crack between the dash and frame, and hook it up to your light switch for power. then to get it to the engine bay you might have to drill a hole in the firewall if there isnt one for wires already (some fords have a hole in them for audio stuff i guess)
jwog666
Dec 27, 2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
