intakes
intakes
whats the best type of intake for a gt mustang? mines a 1997, i wwant to get the BBK fenderwell intake so it sucks in cold air from where the tires are, but i see alot of you have just a k and n and a cold air wall around it, what do u guys think of those? do they help? cuz i would think they just suck in a lot of engine heat with or with out the cold air wall. oppinioins pleased
RE: intakes
As far as performance goes, there are better places to spend your money than CAI.... They do spice up the look under the hood however though which might be worth the price alone. I would recommend the JLT. It is plastic, has a heat shield and can be painted to match your car. The fenderwell VS short ram style will not give you any big difference in gains.... I like the short ram style because you can see the filter and I think it looks cooler. Just my $0.02
RE: intakes
some say a engine bay filter such as the k&n do better because of the streight shot. others like the fender well because it is pulling true cold air but has the bend in it. honesly it really doesn't matter theres not enough diffence that you will ever notice.
RE: intakes
You have to do the whole intake "system" to realize the most gains. That means new plenum, TB and CIA all at the same time. They are meant to work together for the best output. One without the other really doesn't accomplish all that much. If you want, just spend the money on a new plenum and throttle body and take out the air silencer from you air filter box and install a K&N filter instead of having to pop for a completely new CIA. That is almost the same anyway. I suggest Accufab for the plenum/TB combo. They have quality parts and dynoed tops. Good luck with your ride!
RE: intakes
hmmmmmm ill prolly just get a filter and a cold air wall, i couldnt feel a silencer on my intake piping when i was looking for it the other day, so im assuming it already gotten tooken out. it makes a big suckin noise when i turn the car off
RE: intakes
If you can see your air filter inside its housing and a hole in the fender then the silencer has been removed. Its a rubber piece that connects to where the air filter is. No feeling is involved.
RE: intakes
hears a write up on how to remove the intake silencer.
http://www.mustangworld.com/ourpics/fcar/intke.htm
just do that and see if its there
RE: intakes
welll on my stealth it was under neath the intake piping well it was an intake resonator i figured a silencer and a resonator was the same thing lol... by taking out the silencer does that improve anything? cuz its sucking air from the fenderwell with it, with out ud tihink it would help less? its it a good deal?
RE: intakes
I was going to get the JLT CAI and figured it doesn't seem to be worth it without doing the TB/Plenum at the same time. Since the plenum will be off, I figured I'd throw an NX plate kit in at the same time. Do you think I will notice anything with these mods? No, really, don't answer - purely rhetorical and sarcastic. How come I feel like someone will post anyway? I love this place, a nice friendly place where sarcasm gos to die...
Seriously though, with the 'whistle' I've been reading about with CAI/TB/Plenum upgrades, do the fender CAI's make less noise than the RAI style intakes? With the opening being burried in the fender well, won't some of that noise be muffled slightly or is the noise from the system itself and not out of the business end of the filter? If the fender well style isn't any quiteter, then I'm going with JLT's RAI cuz that big 4" tube looks pretty mean...
