HELP!!!Engine Code Trouble!
Old Feb 25, 2006 | 12:30 PM
03redGT's Avatar
03redGT
Default RE: HELP!!!Engine Code Trouble!
i know, just an abundance of similarities to my problem with my cougar. just trying to help
Old Feb 25, 2006 | 03:34 PM
BCisme's Avatar
BCisme
i suppose a bad injector would cause you to run lean.
Old Feb 25, 2006 | 11:15 PM
RedRoller's Avatar
RedRoller
ok thanks alot 03 red gt my dad was also sayin it might be a plug but i put new plugs in it about 5 months ago(some kinda NGKs) do u think they mighta gone bad?I have those Screamin Demon coil packs and Livewires so that may have had somethin to do with it? They might need a different plug to run properly i really dont know
Old Feb 26, 2006 | 01:25 AM
03redGT's Avatar
03redGT
yeah with my cougar i installed those bosch platinum plus 4's and it ran like hell, theni got some platinum coated ford plugs nad it was like my car got laid. coil packs arent always reat for the engine either. maybe its faulty. id try getting some platinum motorcraft plugs, they are cheap and it might solve your problem. otherwise check into your coil pack, and make sure you dont need to adjust the spacing on your plugs before install, that could be it too, since the coil pack helps produce more spark, your plugs might not be spaced enough you can get a plug spacer at any autopart store, and a car manual will tell you what ot space it at, so should the coil pack company. and then check your 02 sensors.
djbigskrilla
Sep 20, 2022 01:04 AM
Granatelli Sales
Jan 20, 2020 12:34 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
