HELP! EXTREMELY URGENT
i just put on my new intake and i think i have leak maybe on an injector. WOULD i I KNOW FOR SURE??? like stumbling, and rough idles cause its perfectly normal sounding. QUICK tell me
ORIGINAL: 97BlackStang
cuase theres a little bit of a shimmer to it, and its fuel, but i think that its has just spilled on there from when i put it back together. O and now i shut it off, and now it wont start?!?!
I think i have a leaky injector. But it runs fine. The reason it would start was because i had a coolant temp sensor off. Then is started up. A little slow but it runs. I have some coolant leak issues to adress, but thats 2marrows project.
You put a pi intake on it didnt you . If so here is whats probly wrong first did you make sure that you put pi gaskets on cause if not the non pi wont work they leak i did it cause the guy sent them to me with the swap kit. Also the water leak is around your coolant jackets they have to be permatext you have to go around them cause they dont match up perfectly.
