HELP! EXTREMELY URGENT
Old Feb 26, 2006 | 02:50 AM
97BlackStang's Avatar
97BlackStang
Default RE: HELP! EXTREMELY URGENT
Its not the water jackets those are perfect. The coolant temp sensor on the right side viewing it from the front started leaking after it warmed up. And around the thermostat housing also once it got warm. And its not a PI intake.
Old Feb 26, 2006 | 04:16 PM
beheivjer's Avatar
beheivjer
take some starting fluid alittle not alot and mistaround the injector the vacumn areas if it reves alittle there it is. dont go crazy with the fluid though
Old Feb 26, 2006 | 04:28 PM
97BlackStang
So get some, and spray from a distance from the suspect injector, and if it revs a little its leaking? Is there anything else i can spray onto it? to get the same results
Old Feb 26, 2006 | 04:36 PM
98slowmustanggt's Avatar
98slowmustanggt
carb cleaner will work also just go easy on whatever you use or just go ahead and buy new o rigs i cant see them being very much and they are simple change.
Old Feb 26, 2006 | 04:46 PM
97BlackStang
Thats why im questing if its leaking or not, becuase i have put new orings on as i put it back together. They were a dollar for 2 by the way
Old Feb 26, 2006 | 11:39 PM
GTuner's Avatar
GTuner
ORIGINAL: beheivjer
^^^^^^^^ +1
Old Feb 27, 2006 | 12:08 AM
97BlackStang
It didnt rev, so i guess im good My dad brought up a concern of his thought that the leaking fuel may catch fire. But i dont think the block will get hot enough to reach the flash point of fuel
Old Feb 28, 2006 | 10:45 PM
98slowmustanggt
If its leaking fuel you need to get it checked out man its not safe for you or anyone else on the road around you .
Old Mar 1, 2006 | 12:55 AM
97BlackStang
It stopped for sure. Everything is working perfectly now.
KingRando
Oct 1, 2015 11:16 AM
Gkid182
Sep 22, 2015 08:17 AM
Sep 16, 2015 07:53 PM
Sep 8, 2015 11:50 AM
M3hunter
Sep 5, 2015 03:42 PM
