thinking cams.
thinking cams.
thinking cams......
what other minor mods work best in conjunction with stage 1 or 2 cams.
any driveability issues from those of you with cams?
what should i do to get the most out of the cams?
RE: thinking cams.
ORIGINAL: nathansmith50
thinking cams......
thinking cams......
2) What are you future plans?
3) What is your budget?
***You'll get a better response if you post answers to the aformentioned questions***
RE: thinking cams.
active hood scoop CAI
3.90 gears
flows
other than that it's suspension mods.
future plans:
t-56
full exhaust
possibly a supercharger(but i'm not sure about this one.
then the other common bolt ons......
3.90 gears
flows
future plans:
t-56
full exhaust
RE: thinking cams.
save the money ud waste on cams n get a supercharger.... cams wouldnt do u much good unless u had blower cams after u got a blower. cams are like 700 bucks for everything and a lot of work for 15-20 hp. just my personal opinion, ur money could be better invested somewhere else
RE: thinking cams.
wether or not i get a blower depends upon wether or not i can find a nice fox coupe to build.
if i can then i'm not going to do anything much else to my gt......if not.....then when my gt is paid off then all bets are off and i'll go wild.
RE: thinking cams.
ORIGINAL: code3GT
Stock internals??? Do a set of Stage 1's and call it a day.
+1
Going to a stage 2 requires full exhaust and intake and MUST also forge the bottom end (internals: pistons, rods, crank, etc.) As mentioned before, if you do get a blower, you have to get special cams, same goes with a bottle set up. look here at vt:
http://www.vtengines.com/
