To make street tires sticky.... burning out is not gonna help you, its gonna hurt you. You can do a quick chirp of the tires to get the nasty off the tires but thats about all you wanna do. As for drag radials... a nice 5-10 burnout will warm them up good and be pretty sticky at the track.
Stick it in 2nd if your on dr's rev it, dump it, and get back on the brake. hold it for 5-10 sec. and then let off the brake and roll it out. They should be sticky. Chirping street tires will be sufficient
What gear you are in depends on gearing. Stock gears I wuold burnout in 1stespecially on the stock clutch. If you have 3.73's or 4.10's 2nd is probably a better bet.
