Tune question
Old Jun 23, 2007 | 11:50 AM
slick 03's Avatar
slick 03
Default Tune question
Ok i did a search and didnt get a positive yes or no.I will start by telling you i have a 2003 gt, bbk underdrives, bbk cai, bbk short tube headers, no cats, flowmaster 40s, and 3.73 gears, and its an auto.I bought the car this way. Now if the car was tuned and i disconnet the battery will i lose the tune.And if i buy a tuner will i be able to tune it. Thanks for the help.
Old Jun 23, 2007 | 11:54 AM
2002blkgt's Avatar
2002blkgt
Default RE: Tune question
if the car has a computer tune and you disconnect the battery, that doesn't change the comp. because it was flash tuned. you have to have a stock tune installed to use a handheld tuner. if the owner didn't give you a tuner with the car then it is probably stock. i would contact the previous owner and ask.
good luck!
Old Jun 23, 2007 | 12:22 PM
slick 03's Avatar
slick 03
Bought it from the local ford dealer.Ran a check on the vin number for giggles on it came trom an auction. So i have nobody to call.Out of state auction
Old Jun 23, 2007 | 12:37 PM
oxfordgt's Avatar
oxfordgt
If you buy a tuner you can use it. The tune that is inthe carnow will be stored as factory tune in the tuner.
Old Jun 23, 2007 | 12:47 PM
slick 03's Avatar
slick 03
Thanks thats what i needed to know.
Old Jun 23, 2007 | 03:32 PM
zincyellowgt's Avatar
zincyellowgt
Ford can install the factory program and reset thecar to factory if you so desire. However, as oxford gt states, you can by a programmer. It will recognize the current tune as the factory. With regard to the batery disconnect. IAW a Ford technician this will only reset data collected by the computer and/or reset a CEL that has popped up. I have done this with regard to a CEL I had prior to taking it in for diagnostics per the technician. The CEL reset but came back approximately 50 miles later as he stated it would if the problem was still occurring. FYI. More info with regard to this at www.brenspeed.com where they discuss the caution of protecting your custom tunes prior to taking your vehicle into a local dealer for service. Good stuff.
Sep 8, 2015 06:25 PM
cbird1177711
Sep 3, 2015 08:43 PM
whatsup62
Sep 3, 2015 01:38 PM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 1, 2015 08:16 PM
