just installed 4.10's...
#33
![Default](https://mustangforums.com/forum/images/icons/icon1.gif)
i wanted to get some gears. i dunno what i have in right now...i saw earlier someone mention that u actually get to use 5th gear in normal city driving...which i DO actually use 5th gear in normal city driving. so i guess i have 4.10 gears? or atleast close to it? i ultimate goal is to have my car run E.T.'s of 11's so should i go with 3.73 or 4.10's?
#34
ORIGINAL: 96GT_PSL
#35
Alright guys, I think this might help some of us to visualize things. At normal cruising speeds, here's the approximate difference in RPM between gear sets:
3.27:1-- Stock
3.55:1 -- +175 RPM over stock
3.73:1 -- +300 RPM over stock
3.90:1 -- +400 RPM over stock
4.10:1 -- +525 RPM over stock
4.30:1 -- +650 RPM over stock
These aren't really exact, but will give you a pretty good idea.
3.27:1-- Stock
#36
so what ur saying is with 4.10 gears u'll have to shift when u hit approximately 525 RPMS higher than stock? [&:]i havnt started college yet so im still not quite knowledgable about all this stuff lol. but gimmie 2 years after i get my degree in automotive technology and ill know my shiznit
![Big Grin](https://mustangforums.com/forum/images/smilies/biggrin.gif)
#37
ORIGINAL: 2000GT4.6
Both the 45 and the 3650 were/are made by tremec, and both of them have virtually identical 1st gear ratios. Unless you are refering (aka you have installed) a TKO 600 you do not have the 2.87 first gear ratio.
T-45:
http://www.ttcautomotive.com/English/products/T-45.asp
T-3650:
http://www.ttcautomotive.com/English...ts/TR-3650.asp
The 600 is the only trans that has a 2.87. In any case, the entire BS about 4.10s making 1st useless is just that... BS. The only way it is useless is if your running stock style tires and get no traction.. but its not the gears fault, its your tires/driving!
ORIGINAL: zincyellowgt
I am so happy I went with 4.10 gears. MPG going to North Carolina was 25-26 MPG highway with 5 speed tremec 3650. This is an overall round trip average that I checked at each and every fill up. I could not believe the results and double checked the math each time, but I in fact got 25-26 MPG and was running 65-75 MPH average. IN town I get about 18-20 depending on how much stopping and starting I am doing. And yes 1st gear is still very useful. People don't real;ize that the 1st gear on a tremec is 2.87:1 ratio as compared to the 3.35:1 first gear ratio on the T45.
T-45:
T-3650:
#39
ORIGINAL: MineralGrey
actually it's closer to 2650 2700, compared 2000 2100 w/ 3.53's.
ORIGINAL: cixx01gt
2800 at 80?
2800 at 80?
