Oh Boy. Whats wrong
Old Jul 10, 2007 | 06:24 AM
dstangrunner's Avatar
dstangrunner
Default Oh Boy. Whats wrong
Well my car seems to be miss fireing at low rpms. If i have it at high rpms its runs fine except for a little power lose.
I have ngk plugs with about 30,000 miles on them. I also have 110,000 on the coil overs. Can anybody help.
Thanks.
Old Jul 10, 2007 | 06:28 AM
BleedinBlue's Avatar
BleedinBlue
Default RE: Oh Boy. Whats wrong
Thats not much info to go on. Start with a typical tune up, change out the spark plugs, fuel filter, etc...
Old Jul 10, 2007 | 07:15 AM
xcodegt's Avatar
xcodegt
Check/change the coil packs
Old Jul 10, 2007 | 07:19 AM
dstangrunner
How can you tell if the coil is bad? How does a bad one look like?
Thanks
Old Jul 10, 2007 | 07:54 AM
Sniper6677's Avatar
Sniper6677
unplug it, take out the coil bolt and remove. look inside the coil and check for rust or corrosion, maybe schmutz a little dielectric grease in there while your at it as a quick test.
Old Jul 10, 2007 | 09:49 AM
Brute03's Avatar
Brute03
did you wash your engine recently?
to test then you'll need a multimeter so you can check the primary and secondary resistance.......... but i don't think it's the coils just yet, i would first change the fuel filter and plugs since it's probably about that time anyway
Old Jul 10, 2007 | 09:52 AM
HMUSN's Avatar
HMUSN
ORIGINAL: dstangrunner
Thanks.
sounds like it could be a vaccume line.
open your hood and check the connections to your throttle body and see if anything is loose
Old Jul 10, 2007 | 03:55 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
NGK makes a wide variety of plugs so saying "I have ngk plugs" doesn't tell us much--however if what you have are plain 'ol copper core conventional electrode plugs then you can bet they are shot at 30k miles...
Old Jul 11, 2007 | 11:38 AM
Chris98Gt's Avatar
Chris98Gt
check and see if the plugs are gapped right too.
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
marc954
Sep 29, 2015 11:18 AM
