Changing Rear Gears
ORIGINAL: Gar4pt6
you are saying that 300-400 should be out the door for the initial cost of gears and the installation cost???
shouldnt it be about $300 for installation alone...then you have to buy gear oil....gears (150 and up)...speedcal or tuner (100-400)...bearing kit if you have more than 50k miles most professionals will recommend one (100)...might as well throw some new clutches on that posi while you are in there.....
i added it up for me and between gears, rebuilding the posi, installation, a tuner and tune it will cost me $1k + or - a couple hundred
ORIGINAL: 2000GT4.6
If the part in bold is true, you have no business doing it alone. Take it to a shop, if they are charging more than 300-400 bucks for the gears and install they are raping you. Go to a mustang specific performance shop, they will do a better job at a cheaper price generally, and since the install really hasn't changed since the foxbody days they will surelyi get it right.
ORIGINAL: KartR31487
Ive never opened up the rear end on a car, and dont know what to exactly expect right off the bat.
How hard is it to change the rear gears your self? I have access to a car lift, and can get any tool I'll need. Are their any speciality tools I'll need to get? Anyone have any advice or a guide?
edit: taking out the 4.10s and going back to 3.73s.
So far as the speedcal, you can spend 100 bucks and get one, or you can buy a handheld and have something you can use more of in the future. I wouldn't count the entire speedcal cost as part of the gear install, as you also get the ability to adjust your tune, datalog, etc etc.
inyadreems
Aug 21, 2015 09:10 AM
