downshifting
ORIGINAL: MrChubs1
Downshifting wears everything (but the brake pads) more, plus burns more gas.
The trans bearings see negative load, the clutch gets worked more, the synchros get more work (just more shifting frequency) and the engine itself gets negative load, which wears the rings more and is actually much tougher on the rods and rod caps than accelerating. They're not designed to handle extreme negative loads that are actually pulling on the rod bearing caps.
That said, normal driving decel probly isn't a big deal. Coasting is always easier on everything though.
I coast. Except when I'm coming up to someone I know and wanna show off or somethin, then I'll give a little downshift here and there.
ORIGINAL: 96GT226410
Downshifting is for idiots who like their exhaust too much. I'd rather keep it in whatever gear I'm inalready until RPM's get too low and then just throw it in nuetral, most of the time not hitting the clutch. Why put all of the wear and tear on your clutch and tob when it's not needed?
I throw the clutch in and pop it out of gear and brake to a stop.........but i do have a a question of when ya pull up next to someone that wants to try u and ur running between 60-70 and throw it in 3rd and let her rip how bad is that????
u shouldn't have the car in neutral AND have the clutch in. the clutch should beused for changing gears only, don't ride the clutch.
that being said, if i have to slow down quickly i will engine break. the best thing is to just watch your speed and plan appropriately.
Normal down shifting will not hurt your clutch as long as you aren't trying to downshift over revving the motor and tranny. There is nothing wrong with downshifting as long as it is not abrupt.
You got to love that exhaust sound andwho cares about gas mileage anyway. The car is mean't to downshift it is a sports car for **it sake.[8D]
