N/A Beasts. . . .
ORIGINAL: MustangGT99
zw....what do you have for a set up to make those numbers, what are your 1/4 times
I've not been to a 1/4 mile, but I've made ALOT of passes in the 1/8 mile. My best to date is a 8.16@85+ which would be mid-high ~12's. I've been running a 275/40/17 D/R, with pretty crappy 1.8-1.9 60'fts.
The car should have no problems being a 12.50 or better car as it sits with a decent tire.
Here is a bud of mines:
Patriot heads and cams
Fox Lake P51
CPR fuel rails
30lbs injectors
Lightning 90mm MAF
Anderson Powerpipe
Bassini X-pipe and catback
Mickey drag radials
Best-12.71 1.8-60 109 MPH
N/A
Fox Lake P51
CPR fuel rails
30lbs injectors
Lightning 90mm MAF
Anderson Powerpipe
Mickey drag radials
N/A
ORIGINAL: ben790450
Zach man you and me need to line them up here sometime. Once i get some DR's . . . .
ORIGINAL: code3GT
http://video.google.com/videoplay?do...45831904994743
If ya look to the right....There are some other N/A vids under "Other vids from this user". ENJOY
ORIGINAL: CoolAid
Fricken' wild how you launch off the limiter. Kewl azz ICE.
ORIGINAL: code3GT
