Speedometer question...Need help
I bought my car used and noticed that my speedometer was off. I had someone drive next to me and I was going at least 10 mph slower than what it said on the speedometer. Anybody know why its off or if i can change it back to normal?
you might have different gears in it i just had 4.10's put in mine today mine does the same thing take it to the ford dealer they can do it for 80 bucks. Better then buying a $380 tuner.
or you can take the diff cover off...drain all the oil...count the number or teeth on the ring gear and divide that by the number of teeth on the pinion gear...this gives you your ration....example...41/10 = 4.1....4.10:1 gear ratio
or do it with the lil computer calculator thing
