stick or auto?
Old Jul 26, 2007 | 08:30 PM
jedfrisby's Avatar
jedfrisby
Default stick or auto?
I have a 01 twin turbo gt. It puts out 438rwhp and 592ft lbs at the wheels. I plan on buying a long block when the motor goes so I can cut up my boost. My goal is to have one reliable fast as hell street car. I finally carried it to the track last friday. It pulled the front tires in first. it seemed like It was going to be a good pass til I shifted to 3rd, there was nothing and the same for 4th. the stock t45 tranny is shot. I just finished putting a spec 3+ ($489)cluth in the day before. So I have a bad *** clutch if someone makes a descent offer. Anyways, I don't know wether to go with a tko 600 or an auto? Which will be the cheapest route and most reliable once I am pushing about 650rwhp. Any complete kits with driveshafts out there. Also it has to have overdrive cause A true street car drives to the track. Thanks guys
Old Jul 26, 2007 | 09:55 PM
silverstang1996's Avatar
silverstang1996
Default RE: stick or auto?
honestly if i were you i'd go auto. poeple say a manual is more fun and all but just think, if you miss a shift with that built up of a motor and blow it up, you won't be too happy about that. and another simple fact about the auto is you won't miss a shift 100% of the time. Down at the strip it will also help with your times, you will be running more consistent times and all. If you'd put a good stall and shift kit in your auto tranny you'd eat up any manual out there. But as i said, alot of people do like the fun factor of a manual, being able to control your shifts the whole way through instead of just 1st and 2nd gear.
Old Jul 26, 2007 | 10:05 PM
meechuacon's Avatar
meechuacon
I like manual tranny's personally. But with that much power I would probably consider the auto.
Old Jul 26, 2007 | 11:45 PM
Ahnial8u's Avatar
Ahnial8u
Those 2 should never be in the same sentence. Do it right or you will be doing it the cheap way over and over!
Old Jul 27, 2007 | 12:30 AM
rbstang's Avatar
rbstang
auto would be better at track imo... but i had an auto v6 and i will never get another auto car. so id say tko600 considering it can handle a lot of abuse
Old Jul 27, 2007 | 01:41 AM
CobraStangGT16's Avatar
CobraStangGT16
You will NOT be dissapointed with the TKO 600. My dad's running it in his Cobra, and he has about the same amount of power you have, and it's the most reliable tranny you can buy.
Plus, if anything ever goes wrong, you can do a rebuild kit on it. Can't do that with an automatic...at least not by yourself. I mean, have you ever seen an automatic tranny cut-away? It's like a damn labrynth in there...sooo many confusing parts. It's easily the most complicated part on any car.
Old Jul 27, 2007 | 10:15 AM
silverstang1996
Well cobrastang the thing is with the auto if he just buys a brand new one to handle that power easily he won't ever really need a rebuild kit because there shouldn't be anything that would go wrong with it that he would need to rebuild it, unlike missing a shift in a manual and what not. If I were you I'd just deffinetely go with the safe route and buy the auto so I would know I wouldn't be risking hurting something with all the money you have put in your car.
BeatnikFink
Oct 1, 2015 08:00 PM
fastbackford351
Oct 1, 2015 12:24 PM
wraith777
Sep 28, 2015 10:49 AM
Sixer4Life
Sep 28, 2015 07:05 AM
2poor4u2
Sep 26, 2015 11:08 AM
