gear whine
Old Jul 27, 2007 | 08:23 PM
Trent97's Avatar
Trent97
I ♥ Acer
Default gear whine
I had 410s installed a while agoand I hear a slight whine mostly in 4th and 5th gear when I let off the gas. Its not really bad though. Will this cause any damage to the rear end at all?
Old Jul 27, 2007 | 09:00 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Default RE: gear whine
No one cananswer this by reading a posting on a forum--find someone with some experience and have them listen to it. As a rule of thumb lowergears (numerically higher ratios) tend to be a bit noisier than higher gears, they can also make backlash a bit more noticable--however it can bea very subtle difference...
99gtstang's Avatar
99gtstang
ORIGINAL: Trent97
mine does it too
from what i understand drive until it's annoying loud
well i started driving it again1k miles later just as loud....
i put new fluid in the chunk and no metal shaving a slight bit on the magnetic plug and that's about it
Old Jul 27, 2007 | 09:01 PM
99gtstang's Avatar
99gtstang
ORIGINAL: Trent97
what brand?
Old Jul 27, 2007 | 09:03 PM
Trent97's Avatar
Trent97
I ♥ Acer
FRPP
Old Jul 27, 2007 | 11:30 PM
Trent97's Avatar
Trent97
I ♥ Acer
any others?[>:]
Old Jul 27, 2007 | 11:48 PM
rbstang's Avatar
rbstang
A) You didnt break them in correctly
B) The shop didnt align the shims correctly
so if you did what you were supposed to then take it back to the shop and tell them to fix it cuz its there mistake FRPP's should never whine if there installed correctly and broken in correctly
Old Jul 28, 2007 | 10:30 AM
MrChubs1's Avatar
MrChubs1
I've heard Richmond gears are tough, but tend to whine a bit more than most other brands. Nto sure what you have though.
I've also heard that if improperly setup (causing a whine), if you leave it that way, the gear teeth faces will wear a harmonic type of pattern that will make noise even after you correct the setup issue. not sure if there's really anything to that - just passing on what I heard.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
