do I ask difficult questions?
Old Aug 8, 2007 | 08:53 AM
  #21
01GT4.6's Avatar
01GT4.6
Default RE: do I ask difficult questions?
ORIGINAL: code3GT
I try to not answer unless I have personal experience. I try to not say, "I have heard or my best friend's uncle's second cousin once removed's last girlfriend's 1/2 brother had a car..."...LOL
so then I guess that you didn't need to vent the valve cover or delete the EGR? Did you have any issues? If it's something that doesn't need to be done, I'm fine with leaving "well enough alone", I just don't want to miss out on something so easy if it could actually be benificial...
Old Aug 8, 2007 | 09:12 AM
  #22
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: 01GT4.6
ORIGINAL: code3GT
Like I said, I have the driver side valve cover vented.
Old Aug 8, 2007 | 09:38 AM
  #23
contentsunderpressur's Avatar
You will always have a little compression get by the rings into the crankcase. The egr doesn't pull that pressure from the crankcase, only the pcv valve in the passenger valve cover and the vent in the drivers valve cover do that. If you block off both of them then the pressure will exit at the easiest place which is the dip stick tube. It'll blow the dip stick out and blow oil everywhere. You need to leave the pcv on the passenger side alone but you could put one of those little filters on the drivers side if you wanted.
Old Aug 8, 2007 | 12:40 PM
  #24
ZW99GT's Avatar
ZW99GT
I also feel your pain man. If your title doesnt consist of NEW RIMS!!!!! or WHAT X PIPE SHOULD I GET!!!!!!????? it seems like no one answers anything.
I haven't done either, but I need to.
What exactly is the ADVANTAGE of EGR delete? It seems as though it would lower intake temps pretty good? Definately clean up the engine bay. Anything else guys? I am interested in doing this.
Old Aug 8, 2007 | 01:07 PM
  #25
oxfordgt's Avatar
oxfordgt
Deleteing the EGR does nothing performance wise just makes it look clean in the engine bay. You have to tune your computer if you delete it or your car will run like crap.
I vented both valve covers to keep oil out of my intake. Look at the thread about it and you will see how it all looks.
Old Aug 8, 2007 | 02:53 PM
  #26
ColinGT's Avatar
ColinGT
looks like alot of people helped you in ur first thread. or atleast commented it.
Old Aug 8, 2007 | 10:08 PM
  #27
01GT4.6's Avatar
01GT4.6
ORIGINAL: ColinGT
yep, I guess this thread helped . It seemed that after a day and a 1/2 of no replies it was getting stale
Old Aug 8, 2007 | 10:52 PM
  #28
Sxynerd's Avatar
Sxynerd
ORIGINAL: code3GT
+1
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
