Ford C Springs updated
I have them on my car now. If i was to cut maybe a half coil off the front will it throw my car out of whach that much? I just want the front a little lower, and have the stance. The backs are made to cut off the dead coil right? Are the fronts?
RE: Ford C Springs
ORIGINAL: lizzyfan
You should have gone with H&R or Eibach sporlines if you wanted more of a drop. Just seems like a hassle
at first i was to worried about being to low. I have a gravel driveway with a big up and down hill on it!
butlowering another quarter inch or so with half coil shouldn't be too bad should it?
RE: Ford C Springs
ORIGINAL: BleedinBlue
That drop is with C springs? It looks really low now. Maybe its just the pictures...
but my driveway is angled a little.........
there is about a 1-1.5 gap between tire and fender
rear i took out all the rubber mounts so that my be one reason it looks lower... and for some reason the 315s and 275s madethe gap look more filled in then theregular 245s, i quess because its closer to the outer fender hell i don't know why
RE: Ford C Springs
just cut'em not a huge difference i took some pictures while it was sitting in the same spot!
alot easier with air tools and the 3rd time changing springs
took about 45 MIN.
[IMG]local://upfiles/42821/86CA2EE3C37046CEBB61C12EBC91E859.jpg[/IMG]
[IMG]local://upfiles/42821/3458D103929944A5B1D0482EE0F2A368.jpg[/IMG]
took about 45 MIN.
