nitrous ?
Old Aug 30, 2007 | 10:26 PM
01snake's Avatar
01snake
Default nitrous ?
thos with nitrous what do you prefer WOT activation or button activation?
i plan on getting a window switch so just in case i miss that shift i doen lean
Old Aug 30, 2007 | 10:30 PM
01GT4.6's Avatar
01GT4.6
Default RE: nitrous ?
WOT FTW
Old Aug 30, 2007 | 10:32 PM
01snake's Avatar
01snake
that what im think i have been lookin at the nx kit with tps (that is WOT) correct
Old Aug 30, 2007 | 10:34 PM
01GT4.6's Avatar
01GT4.6
ORIGINAL: 01snake
NX kits come with a WOT. I always thought that a "TPS" was a throttle position sensor, maybe NX now calls their wide open throttle switch a throttle position switch...
Old Aug 30, 2007 | 11:02 PM
01snake's Avatar
01snake
http://www.nitrousexpress.com/Pages/fly_by_wire.htm
thats the one im lookin at w/ a 15lbs bottle
there genx package, and window switch
will i need to run diffrent plugs with it?
Old Aug 30, 2007 | 11:45 PM
02StangGuy's Avatar
02StangGuy
not sure if you HAVE to run diff plugs but i know its a good idea....i just had mine tuned a had the plugs changd as well.....and yes...wot switch is nasty!!! with the window switch you can set what rpm the nitrous kicks in at and what gear also....dont set it for the 1st gear lock out...i thought that i would blow the tires off if i sprayed in first but i diditn at all...the thing hooked and pulled very hard...set it to kick in around 3k tho
Old Aug 30, 2007 | 11:49 PM
REDSTALION's Avatar
REDSTALION
ORIGINAL: 01snake
use NGK TR6's
Old Aug 31, 2007 | 12:49 AM
01snake's Avatar
01snake
you can control what gear it kicks in also? damnn
well i will be doin 4.30's with either 100-150 shot depends on m/t et streets.
so i think i will have it kick in at 2nd(due to me still having irs) [:@]
Old Aug 31, 2007 | 02:00 AM
Zoie_daGT's Avatar
Zoie_daGT
I have NGK TR6s which are one heat range colder.
WOT FTW!!! You have the right idea. This way, you dont accidently freeze up and push the button at the wrong time or low rpms.
[align=left] [/align]
Old Aug 31, 2007 | 03:43 AM
cammed99gt's Avatar
cammed99gt
WOT all the way.I used zex plugs and didnt have a problem.A friend of mineused the zex plugs with a 200 shot on his 99 cobra with out a tune and he went though tons of bottle with out a problem
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
