WOW WAT A DIFFERENCE!!!!!
RE: Tri-ax owners cometh...
ORIGINAL: yelw02GT
nice, i have one myself, instal is kinda self explanitory nothing to it..just take it apart, clean the tranny surface where the shifter and tranny meetreally good with a razor blade, make sure you take the little plastic cup thingy off the ball of the stock shifter and put it on the new one, goop some RTV on the bottom on the shifter or on the tranny surface, make sure you get some around where the bolts go threw, thred the bolts and crank it down, adjust the bumpstops if you want for peice of mind
Take the little plastic up thingy off the ball of the stock shifter and put it on the new one, goop some RTV on the bottom on the shifter or on the tranny surface, make sure you get some around where the bolts go threw, thred the bolts and crank it down,
Dude you have to stop watchingmustang ****......
install was a breeeeze, hardest part was getting the damn dust gasket thing to line back up with the plate. other than that it was simple. if the mgw is the best shifter i can even imagine wat thats like, cause the tri ax is soooooo nice
i was proud of my self though, the only thing that i have done on my car other than this was swap out intakes. i gain more n more confidence in myself as i go along...it really helps to read directions to! haha
i hope that is the one where it helps tofind 3rd gear for you
i thought i had that one with my steeda and ended up not finding it and f'in up my 3rd gear snycros and blowing a clutch up[:@]
lol u must of had the "sport" shifter then cause all i haveto do is tap up from 2nd n its right there for 3rd. its great for the 5-3 downshift to cause its always set up to go into 3rd and 4th best mod to date!
