WOW WAT A DIFFERENCE!!!!!
Old Sep 3, 2007 | 09:17 PM
H0SS302's Avatar
H0SS302
Default WOW WAT A DIFFERENCE!!!!!
Got it installed and it is freakin saweet!
Old Sep 3, 2007 | 09:20 PM
yelw02GT's Avatar
yelw02GT
Default RE: Tri-ax owners cometh...
nice, i have one myself, instal is kinda self explanitory nothing to it..just take it apart, clean the tranny surface where the shifter and tranny meetreally good with a razor blade, make sure you take the little platic cup thingy off the ball of the stock shifter and put it on the new one, goop some RTV on the bottom on the shifter or on the tranny surface, make sure you get some around where the bolts go threw, thred the bolts and crank it down, adjust the bumpstops if you want for peice of mind
Old Sep 3, 2007 | 09:21 PM
wisk's Avatar
wisk
Not to be an *** or anything, but did it come with instructions? If not did you look on Steeda's website yet? Nearly 98% of the stuff I've put on my car came with good instructions.
Old Sep 3, 2007 | 09:23 PM
wisk's Avatar
wisk
ORIGINAL: yelw02GT
If you mean shift length stop, then DON'T use them with the 3650 transmission. They are already built in and can possibly F the transmission up if you use the ones in the shifter.
H0SS302's Avatar
H0SS302
k cool so its really that easy? It was an old man who i got it from, he pretty much told me how to do it but i just wanted some back up. he told me that it made the car sooo much fun to drive so im looking forward to it. now the swivel socket....can i just go by autozone er something n ick one up or do i haveto buy it in a pack or tools? cause if thats the case...no swivel for me!
Old Sep 3, 2007 | 09:24 PM
H0SS302's Avatar
H0SS302
ORIGINAL: wisk
ORIGINAL: yelw02GT
nice, i have one myself, instal is kinda self explanitory nothing to it..just take it apart, clean the tranny surface where the shifter and tranny meet really good with a razor blade, make sure you take the little platic cup thingy off the ball of the stock shifter and put it on the new one, goop some RTV on the bottom on the shifter or on the tranny surface, make sure you get some around where the bolts go threw, thred the bolts and crank it down, adjust the bumpstops if you want for peice of mind
i have a t45 so im going to use em
EDIT: and im not asking how to install it dude, im just askin if n e body has n e tips for making the installation a bit easier.
Old Sep 3, 2007 | 09:25 PM
Cornbread01's Avatar
Cornbread01
very easy install. just use a small amount of rtv to go around the parameter. after install make sure you adjust the stops. the to bolts one if front and other in back. you want to be able to put it all the way in gear but not to far the stop should be set a litle bit past full engagement so that it can go all the way in but not over. and for the handle use the middle and bottom holes for a shorter throw
yelw02GT's Avatar
yelw02GT
oh, i never heard of that, i got a 3650 and i put mine out just a tit just to make me feel better and i experiance no problems, but ill keep that in mind
Old Sep 3, 2007 | 09:27 PM
wisk's Avatar
wisk
ORIGINAL: yelw02GT
Something about the transmission having problems kicking the shifter out of gear..? It was in my MGW instructions atleast.
Old Sep 4, 2007 | 09:59 AM
H0SS302's Avatar
H0SS302
bump bump, is there an easy way to get the trim peice off without breaking the clips, im more worried about that than the install its self
