gears
Old Sep 11, 2007 | 12:26 AM
AZsFinest's Avatar
AZsFinest
I ♥ Acer
Default gears
can someone explain to me why i would want to change my gears on my car. Or do u even need to change gears on an automatic.
Old Sep 11, 2007 | 12:51 AM
01snake's Avatar
01snake
Default RE: gears
most pople will do 4.10's in an automatic n/a
3.73'sf/i although some will do 4.10's with f/i
basically they get you up and going faster, the higher the gear you go(that is if your hooking)
Old Sep 11, 2007 | 01:14 AM
0hOneGT's Avatar
0hOneGT
Default RE: gears
+1 on most auto's changing to 4.10s. And the benefit of changing gears is that it basically will make you accelerate faster than with stock gearing. It doesn't give you more power, butbasically increasesthe amount of times the wheels spin per revolution of the driveshaft.
Old Sep 11, 2007 | 09:41 AM
Hash06's Avatar
Hash06
Default RE: gears
it acts as a tourque multiplyer sp? it will make you acclerate faster than the stock gears, if you hook up
Old Sep 11, 2007 | 01:40 PM
MrChubs1's Avatar
MrChubs1
Default RE: gears
The torque is multiplied through improved mechanical advantage when you numerically increase the ratio.
Old Sep 11, 2007 | 01:43 PM
sainthk's Avatar
sainthk
Default RE: gears
I think 4:10's would be to high of a gear for an auto. i have an auto and i like my 3:73's, But my next step would be a 3:90
Old Sep 14, 2007 | 10:50 AM
AZsFinest's Avatar
AZsFinest
I ♥ Acer
Default RE: gears
cool thanks. I am thinkin about getting 3:73s but idk yet. I need to do some more research. But how hard is it on your car?
Old Sep 14, 2007 | 11:35 AM
MrChubs1's Avatar
MrChubs1
Default RE: gears
It's no big deal to your car. No worries.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
