lower control arms question
Old Sep 15, 2007 | 03:13 PM
I SwearItsSlow's Avatar
I SwearItsSlow
Default lower control arms question
i went and got my new tires on the car today and while it was on the lift me and the mechanic looked for where an odd sound was coming from.
we found two of the bushings in my lower control arm are bad, really bad. they want over $600 for labor. screw that.
i was just wondering, instead of replacing the bushings, should i replace the whole lower control arm?
any input is appreciated.
Old Sep 15, 2007 | 03:38 PM
8banger's Avatar
8banger
Default RE: lower control arms question
I'm doing just that as we speak(well taking a break)...yes,,,a decent set of LCA would be a better replacement than just bushings....600 labor OMG....I replaced both uppers and lowers in about 3 hours(lower CA bolts frooze in the steel sleeves)....Need drag springs to finish.
Old Sep 15, 2007 | 04:19 PM
I SwearItsSlow
alright thanks much.
yeah 600 is fuggin crazy, time to hop into the manual and see whatll have to be done.
Old Sep 15, 2007 | 06:45 PM
jrherald420's Avatar
jrherald420
do they provide the lube also??? cause they want to**** you!!! go with new lower control arms its cheaper and they arent hard to install some hand tools (but air would be better !) and a jack and some stands and a hour or two and you will be done!!
Tivo304
Aug 28, 2023 12:19 PM
Dragonus18
Sep 9, 2015 01:21 AM
cbird1177711
Sep 2, 2015 04:12 PM
