good cam...????
RE: good cam...????
yeah i mean he would want more power...but idk if he wants ME to have more power haha. i think i can handle it cuz im not crazy in the stang. but hey they just don't believe me haha. but im gonna keep my fingers crossed.and its my mom u gotta worry about haha...shes lets just say paranoid haha. but wht she doesn't know can't hurt her haha.
RE: good cam...????
No problem. The extreme engergy cams that end in AH are for PI heads. Either the XE262AH, XE270AH and XE278AH. The 278s require valve reliefs. VTengines has a good set, without advance timing ground in (like comp does) for an easier install. You sure you want stage 2 cams? With your mods youd see the best street performance with stage 1 cams like VT stage 1 N/A cams and Comp XE262AH cams.
RE: good cam...????
well i mean i kinda wanted stage 2 heads so i just figured stage 2 cams was the way to go. i just saw tht cammed99gt had em so idk lol. just thought it would work better like tht.
RE: good cam...????
ORIGINAL: mustangmancp
RE: good cam...????
The thing with stage 2 cams is your peak power is shifted up in the rpm range, and your bottom end suffers. It may make more peak power than stage 1 cams, but peak power isn't what its all about (which is why Mach1s beat 96-01 Cobras stock vs stock all day long).
Thats why gears are recommended for agressive cams. With the higher rpm power range you take your motor closer to is limits. Forged internals, good valve springs and a quality intake manifold are required to really take advantage of stage 2 and higher cams. The stage 2 heads will work with stage 1 cams though.
Its a lot of money. Keep asking around and see what others recommend.
RE: good cam...????
yeah i probably won't be able to buy it all at once cuz its like almost 2,000 dollars haha. little much. and my dad said we'd get FULL exhaust next year (headers, midpipe, NEW mufflers)
