reliability
Old Oct 6, 2007 | 09:31 AM
fisttaface's Avatar
fisttaface
Default reliability
How reliable would a daily driver 2001 gt be with patriot stage 2 heads ,VT stage 2 cams , trickflow intake manifold , jlt cai, upr o/r x , slp lm1,s diablo tuner , 4.10's, c&l tb / plenum , and NX 50 shot......would i still get a good long life out of it.
Old Oct 6, 2007 | 09:57 AM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
Default RE: reliability
i dont see why not...i wouldnt push much more spray than that though, and even at that i wouldnt spray daily
Old Oct 6, 2007 | 10:11 AM
dtkikols's Avatar
dtkikols
the only reason the car wouldn't last is beacuase even without the spray you would be at about 340-350hp at the crank and with those 4.10 gears your gonna wanna romp on it all the time. but theres no reason why it shouldnt last if you don't tear it up.
Old Oct 6, 2007 | 10:27 AM
97targa's Avatar
97targa
ORIGINAL: fisttaface
That's one hell of a DD! imo. I would stay away from the trickflow intake as they are junk and don't produce the power they claim until like 7,000rpms which you won't see! There's no comparison to the P-51. It's simply the best out there. Honestly I would say save the money and putit towards a built shortblock! If you spray, make sure you have all the safety devices like Fuel saftey shut off switch, rpm limitor and a proper tune with all those extra's. A proper tune should run you about $400 with a couple of diff tune set-ups in your programmer. If you want to keep your stock block, take the money from the trickflow intake and put it towards a set of LT's that you'll benefit much more from!
Old Oct 6, 2007 | 10:59 AM
fisttaface's Avatar
fisttaface
Cool, i am unsure of the adding nos... but i seriously want the heads and cams, i love the choppy sounding idle. I will look at the P-51 intake manifold. I will most likely get LT's , but not till later as i just installed a upr o/r x which woul dbe useless when i get LT's. I wish superchargers were cheaper. Im also swaying on comp stage 2 cames or VT stage 2 cams. Are there any differences in those .
mikecaputo
Aug 22, 2015 10:58 AM
chain
Aug 17, 2015 08:52 AM
bCROWL
Jul 27, 2003 10:56 PM
Redline5th
Jul 20, 2003 12:05 AM
BUDisWeiser
Jul 11, 2003 03:50 PM
