Doing Some Modding, Need Some Help
Old Oct 11, 2007 | 01:24 PM
GTnateGT's Avatar
GTnateGT
Default RE: Doing Some Modding, Need Some Help
Aesome so here ti is,
Im going with the SLP LM1 Resignator
The 4.10's
And the Ford B Spring Lowering kit
Sounds Good For Now
Old Oct 11, 2007 | 01:41 PM
y2kStangGT's Avatar
y2kStangGT
ORIGINAL: H0SS302
the 410 for auto 373 for manula is a bunch of bull****. one person says something n like cows everybody else just follow. 410s are PERFECT for manuals. ford c springs will give you about 1.25 drop for around 100 bucks. i would get the gears before anything else tho.
when can i get spring for 100?
Old Oct 11, 2007 | 02:42 PM
GTnateGT's Avatar
GTnateGT
stangsuspension.com.Seems pretty legit. Check it out
Old Oct 11, 2007 | 02:53 PM
BleedinBlue's Avatar
BleedinBlue
ORIGINAL: y2kStangGT
ORIGINAL: H0SS302
You won't, unless you get a set of used springs. The C springs can be found for around $150 shipped, give or take.
Old Oct 11, 2007 | 03:24 PM
Jono 02 stang's Avatar
Jono 02 stang
Look man 4.10s are badass for a drag race. But in the long run it sucks unless you up the cams and heads on the car and get a higher red line. The other thing is the more poweryou put on your car the harder it is to make the car stick to the street unless you get drag radials and if you race alot or drive the car alot the tires are only going to last a short time.I would get 3.73 or you could get 3.90s which is in between both for a manual and 410s for a auto.
Old Oct 11, 2007 | 03:27 PM
GTnateGT's Avatar
GTnateGT
ok i see, ill just check out the 3.73's or the 3.90's. 3.90's seem to be a good bet. The are in between. I will probably just end up with 3.73's for now tho. Seems like a safe bet. From there ill go up if i need to
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
firecoyote
Sep 27, 2015 02:37 PM
