Idle issues
Old Oct 21, 2007 | 02:44 PM
v8mgt2000's Avatar
v8mgt2000
Default Idle issues
Ok, i read through 40 pages of posts and couldnt find a solution for my problem. I have a 2000 mustang gt and lately its been idleing around 1000rpm at rest, and once in start moving or im slowing down the idle is 1500+ when i put the clutch in. I have cleaned the maf the throttle body, gaped all my plugs to spec, relpaced the idle air control vavle and the throttle possition sensor. Im running out of ideas. All of these things altered the way my car runs but did not solve the problem. I could definitely use some help.
Old Oct 21, 2007 | 03:37 PM
xander0561's Avatar
xander0561
Default RE: Idle issues
carbon build up in your EGR either in the pipe or the valve...
Old Oct 21, 2007 | 04:28 PM
Dan04COBRA's Avatar
Dan04COBRA
You should check the voltage at your TPS rather than just replacing it.
Also, do you have an O/R Mid-pipe with MIL Eliminators?
On my 02 GT my MIL eliminators did whacky things to my car, it would hunt for the right RPM's to idle at. Once they failed, all my idle issues went away.
Old Oct 22, 2007 | 12:13 AM
v8mgt2000's Avatar
v8mgt2000
no, my midpipe is stock i will check out the voltage, thanks
2007StangV6
Jan 28, 2016 06:09 PM
stangin1996gt
Sep 21, 2015 11:01 AM
LivingInThePast
Sep 16, 2015 12:20 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Emblazoned
Sep 3, 2015 10:45 PM
