Cam Pricing?
Old Oct 29, 2007 | 01:40 PM
DuckyGt's Avatar
DuckyGt
Default Cam Pricing?
Called Strictly Performance in Houston to get some advice about a cam install. I told him I wanted a VT stage 1 cam he kept stressing P&P the heads, which I know would be ideal but im not made of money at the moment. P&P isnot really neccesary is it with stage 1? (if i had the money i would just run stage 2 heads and stage 2VT cams). Also this was my quote seems really high to me I could have a sick NX plate kit setup for the price of jsut the P&P. Thoughts?
VT Stage 1 cam= $550
Cam Install= $1000
P&P= $1400
Dyno Tune= $550
Old Oct 29, 2007 | 01:46 PM
ben790450's Avatar
ben790450
I ♥ Acer
Default RE: Cam Pricing?
You dont need to get your heads P&P'd with stage one cams. Itll give you a little more kick but it doesnt matter. For stage 2 heads i would strongly suggest that you get aftermarket or ported heads but honestly i wouldnt really waste my money. And thats dumb. A set of new (stage 1 or 2) heads are like 1250 right now through american muscle and they want to charge you 1400 to port your old heads?
Old Oct 29, 2007 | 01:48 PM
rainydayracing's Avatar
rainydayracing
Wow - $1000 for a cam install?
Old Oct 29, 2007 | 01:51 PM
DuckyGt's Avatar
DuckyGt
They seem be trying to charge out the roof IMO, but I gave them a call anyways cuz they did a good job on my gear install in the past. guess Im gonna have to shop around? what are some reasonable prices for what is mentioned above?^^^^ The spray sounds better and better.
Old Oct 29, 2007 | 02:05 PM
281stang's Avatar
281stang
if you are after performance i sujest that you do the p&p while you have the car apart, or your goin to wish you did later. but if your just goin after the cam sound you'd be ok with just installing the cams, and you will get some hp gain out of it.
Old Oct 29, 2007 | 02:56 PM
05Saleen#243's Avatar
05Saleen#243
modularmustangracing.com
They do a stage 1 P&P for about $550I believe.
Old Oct 29, 2007 | 04:13 PM
droptoppony's Avatar
droptoppony
What was included in the cam install? Are they going to degree the cams and shave the keyway and set your timing perfect? If so then that takes alot of time and could be why its so high for the install.
Old Oct 29, 2007 | 04:24 PM
GhostRider02GT's Avatar
GhostRider02GT
call fastlane, I dont know prices, but they are another shop to try, the have done good work for me 713-600-8600
Old Oct 29, 2007 | 05:12 PM
ben790450's Avatar
ben790450
I ♥ Acer
ORIGINAL: 281stang
No becuase to do a cam install you dont have to take out the heads, which is a huge pain.
Old Oct 29, 2007 | 05:38 PM
97targa's Avatar
97targa
WOW!! Go somewhere's else! First off, $1k to do cams??? It takes like 4 hours to do them! Also, $550 for dyno???? What are they smokin? Should be no more than $350-400. I'm in NY and it's $$$$. The top guy wants $350 for dyno/custom tuning. If you drive the car daily stage 1 is good, if not then go with stage 2. You will need gears for the stage 2, but you will def. notice big improvement. I would say you would notice a bigger improvement with stage 1 cams and a P-51 intake than P&P with stage 1's.
Also, you need to get the heads CNC'd and not done by backyard dremel!!! You can buy all newly rebuilt stage 2 heads for less than they want just to do your used heads! They need a swift kick in the ballz
