oil pan gasket
oil pan gasket
I need to replace the oil pan gasket on an 03 GT auto. Will I have to raise the engine to get enough clearance, or will it slide out?? If I do have to raise it, where are the lift points?
Thanks for any advice
RE: oil pan gasket
You either have to take the engine out or drop the Kmember with the engine supported. How do you know you have to replace the gasket. They are very good gaskets that are hard plastic with rubber. They wont push out.
